AMT's Kitty returns with RAAF markings included
Postby DDGboy » Fri Apr 05, 2019 4:33 am
My error spotting skills BEFORE I hit send/submit - 0.00010%
My error spotting skills AFTER I hit send/submit - 110%
DDGboy
Re: AMT's Kitty returns with RAAF markings included
Postby Sydhuey » Sun Apr 07, 2019 2:14 pm
The 112 Sqn bird is wrong , correct markings and serial but wrong airframe , should be a long tail P-40M Kittty III, not a short tail P-40K Kitty III, should also be Dark Green /Dark Earth over Grey not Desert scheme.
Sydhuey
Postby SMackenzie » Sun Apr 07, 2019 8:25 pm
A29-99 also has problems, the serial should be in Black, a point obvious in photos of the airframe.
Italeri seems to regularly get caught out by using dodgy references for some of their releases.
SMackenzie
Postby Buz » Thu Apr 11, 2019 5:59 pm
They seem to have a number of things wrong with the Kit markings. As Steve Points out A29-99 is incorrect, as is the RCAF Bird (finished in Flat Azure blue, when it should be Sky Grey.
Whilst the 112 SQN aircraft is incorrect as mentioned above, it's actually a P-40K-15 so a long tailed K model, not a P-40M. I do agree the the scheme is more likely to be Green/Brown over grey based on the time the aircraft was with the unit, however the available pictures are not conclusive enough to confirm or deny this fact.
Buz
Buz
Buz
Postby saxon » Fri Apr 12, 2019 4:41 pm
Still have 2 of the original AMT's in the stash bought them almost 20 years ago now. Must build them, I have Aussie decal sheets to go with them. They are basic kits but they look easy and quick to build which is what I'm all about!
