Airfix 1/48 Sea Fury in flight
Postby Kahunaminor » Tue Apr 23, 2019 8:50 am
Here are a couple of in progress shots of my 1/48 Sea Fury for the 2019 Airfix Cup at the NSW Scale Model show on 18/19 May 2019 at the Illawarra Sports Stadium. It is posed in flight with an Aerocraft cowling and a set of Propblur blades:
I used MRP paints (Sky and EDSG) for the first time and happy with the result. The pilot is from the spares box (Airfix Hurricane ?) and the gunsight from an Eduard Spitfire Mk. IX kit.
Kent in Oz
Bench: 1/48 Eduard Bf 109E-7, Libya, 1941; 1/32 Tamiya Spitfire Mk XVIe
Completed: 1/48 SH CAC CA12 Boomerang; 1/32 Eduard Bf109E-4; 1/48 Eduard Spitfire Mk IXc;1/32 Hasegawa Bf109G-6;1/48 Eduard Fw190A-8.
Kahunaminor
Re: Airfix 1/48 Sea Fury in flight
Postby bell209 » Tue Apr 23, 2019 3:51 pm
Looking good so far, Kent
Postby hughb » Tue Apr 23, 2019 7:30 pm
Those prop blades look very interesting!
Postby Kahunaminor » Wed May 01, 2019 8:14 pm
Thanks guys,
Here is the state of play:
Many thanks,
Kent in Oz
Kahunaminor
Postby Kahunaminor » Thu May 09, 2019 10:57 am
Decalling has commenced. I am using the Ronin Decals RDS-152 set and the scheme is “101”:
The decals are really thin and conform well to a gloss surface, however, I had a disaster with one of the “101” fuselage markings and lost it. Operator error all the way (read the decal instructions and avoid setting solutions - water is fine) and my cry for help was answered so the main markings should be complete by the weekend. My only gripe is the opacity is such that the invasion stripes show through the wing upper decals. A lesson for young modellers there. The rocket markings are the kit decals. I will reapply MRP Sky to the mountings before a gloss coat seal:
I fixed a small blemish just behind the canopy. Not sure if I have done enough:
The more astute of you may have noticed the underwing lights should have had “Hawker Yellow” inners and not invasion stripe. Well done but it is on the underside so it stays.
Kent in Oz
Kahunaminor
