Airfix 1/48 Belnehim Mk 1f - completed 13 Apr 19
Re: Airfix 1/48 Belnehim Mk 1f - updated 30 Dec 18
Postby RAAFBrat » Mon Dec 31, 2018 9:25 pm
Hmmm, some small dramas there. Not a great advert for Airfix but you'll sort them, I'm sure.
Postby harvs73 » Tue Jan 01, 2019 12:09 pm
I am fixing up the wing roots as we speak and will have an image of the end result later today. The wing roots look good so far I just need to get better at doing free hand scribing to replace the lost panel lines in that area :-(
Postby Damian C » Tue Jan 01, 2019 4:24 pm
It's all looking nice, build-wise, but it's frustrating when CAD-designed parts just don't fit. I found with the Airfix 1/72 Lightning every insert needed fixing in this regard.
Damian C
Postby Peter Roberts » Fri Jan 11, 2019 5:44 am
Looks like you are doing a great job David. Thanks for posting your build, very informative,
PR
Peter Roberts
Postby harvs73 » Fri Jan 11, 2019 1:43 pm
The wing joints are finished and look better but I do need to learn to scribe better.
The cockpit look ok from the box but there are a number of areas that could do with some scratch building, detailing or PE. If I do another one I will get the replacement instrument panel etc. I am deliberately not putting seat belts on the model as it is being done OOB with no scratch building or additions.
Postby harvs73 » Fri Jan 11, 2019 1:44 pm
The canopy is on and works ok but the arrow head part needs to be fitted as it can obstruct the canopy.
Re: Airfix 1/48 Belnehim Mk 1f - updated 11 Jan 19
Postby RAAFBrat » Fri Jan 11, 2019 3:53 pm
Looking good. That cockpit looks ok OOB but yes, I'd be adding PE. It was pretty cramped in there, wasn't it. The long-nose version fixed that a bit.
Postby harvs73 » Fri Jan 11, 2019 5:13 pm
RAAFBrat wrote:Looking good. That cockpit looks ok OOB but yes, I'd be adding PE. It was pretty cramped in there, wasn't it. The long-nose version fixed that a bit.
I am amazed that they could fit two people in there actually.
A great deal of the interior components in the cockpit could be replaced but I wouldn't bother with the radio compartment as you can't see it once the aircraft is closed up, the same for the turret.
Postby harvs73 » Sat Jan 12, 2019 9:55 am
It is really starting to have that Blenheim Mk 1 look now with the canopy on. You need to be careful with the top part of the canopy as it is wide and may not match up with the lower sections. I ended up have to hold the canopy top wide for a while to allow the glue to dry with the top part on and fitting correctly.
Here is the almost complete turret on the building jig supplied by Airfix. The jig is quite useful but you still need to look carefully at the instructions to work out what goes where and what way.
I contemplated doing some weathering on the turret but as the next picture shows you don't actually see much. The seat and glass still needs to go on which will obstruct even more from being seen. The turret easily slips in to the fuselage but you won't see much inside once it is in there.
Postby RAAFBrat » Sat Jan 12, 2019 10:55 am
Looking good. I presume you acquired a masking set for that? :D
