1/48 RAAF Douglas A-20G - Work In Progress
Postby Sly712 » Thu Feb 15, 2018 1:18 pm
Hi All,
Been lurking for a little while.
So time to bite the bullet and put some of my work up. Didn't get any pictures of the cockpit before I closed her up.
Revell #04598 Douglas A-20G/J Havoc
Vector Douglas A-20G/J Havoc resin cockpit
Aber Browning M2 Aircraft .50 Cal Barrels
Quickboost Douglas A-20G Gun Barrels
Novascale N48018a Decals - "Hilda Shane" 22 Sqn 1944
So far, the build has been fairly painless. Except a builder error when closing the fuselage and realising I hadn't put the wing support in the fuselage!!! :oops:
1/48 Tamiya Ilyushin IL-2 Shturmovik
Sly712
Re: 1/48 RAAF Douglas A-20G - Work In Progress
Postby rodenlee » Thu Feb 15, 2018 1:20 pm
Looking the goods there Sly...keep us posted
What scheme are you planning on?
Postby rodenlee » Thu Feb 15, 2018 1:22 pm
Ahh...read the post!!
Postby Sly712 » Thu Feb 15, 2018 1:42 pm
rodenlee wrote:Looking the goods there Sly...keep us posted
Thanks Shaun.
Hopefully, get some more done this weekend.
Sly712
Postby Sly712 » Sun Feb 18, 2018 4:08 pm
Managed to squeeze some build time in today....between watching the Winter Olympics and the usual tasks the other half wants done :roll:
Some sanding and gap filling, used Tamiya White Putty and Mr Surfacer 1000.
Clear parts got a first dip in Pledge. Another one tomorrow 8-)
Some build for engines, cowlings and wheel nachelles. Hope the I will get a primer on later today.
Sly712
Postby rodenlee » Sun Feb 18, 2018 7:11 pm
Hey Sly
Nice progress. I have one of these to do so watching with interest.
Postby DesTROYer » Sun Feb 18, 2018 8:12 pm
Very nice.
Postby Sly712 » Mon Feb 19, 2018 9:10 am
rodenlee wrote:Hey Sly
It is quite a simple build, the gaps that I have had to fill are quite minor. You could do quite a nice OOB build.
In saying that, if I was to do it again, I would go the Quickboost A-20G Gun barrels and Engines Cowlings. The kit cowling require you to glue on a dozen or so fairings individually. The dreaded carpet monster was waiting for it's next meal, it went hungry in this occasion ;)
Also, while doing my research I discovered that the Novascale decals are essentially wrong, the biggest fault (IMHO) being the serial letters are wrong :( . In real life, A28-60 was coded DU-P not DU-D, why Novascale hasn't fixed such a glaring issue is beyond me.
I am tossing up if I just apply the decals as is or try and source correct lettering and roundels.
Sly712
Postby Antoney Wilkinson » Mon Feb 19, 2018 10:55 am
Coming along very well. Nicely detailed too.
AGW..
Antoney Wilkinson
Postby Sly712 » Tue Feb 27, 2018 10:46 pm
Quick update.
Canopies masked and temporarily tacked on. Tried preshading for the first time :oops:
Carpet monster got a feed....one of the clear oval pieces on the side of the fuselage went walkabout when fitting :roll:
Engines painted. Mr Hobby Burnt Iron, Tamiya Flat Aluminum dry brushing, Vallejo USAF Medium Grey and NATO Black. Oil and grime detailing to follow.
Sly712
