OZCONV4820 OzMods 1/48 Vultee Vengeance update
Re: OZCONV4820 OzMods 1/48 Vultee Vengeance update
Postby harvs73 » Wed May 01, 2013 4:22 pm
I have finally managed to have a more detailed look at the kit in conjunction with the images that Danni has kindly supplied of the real thing. A few comments:
- The fuselage halves needs some clean up at the join but this is to be expected for a short run kit.
- The panel lines on the fuselage in front of the cockpit require one side to be filled and rescribed as they do not line up. The other panel lines that run along the join also need some attention as they don't look correct when the two halves are mated.
- The propeller blades are nicely shaped but the ones in the review sample require to be fixed as they were slightly bent for some reason. This is easily fixed.
- I have compared the images of the real cockpit to the kit and the kit seems to be missing a few components as well as having extra ones that are not on the real one. This could be easily explained by the real one not being 100% complete, more detail will be shown when I am building it.
- The engine is not a complete replica of the original but the ends of the cylinders are hidden by the cowl. You will still need to detail the engine with cables etc as per the build I did but it is ok.
- The canopy is the Red Roo as review here on AMI, there are a few distortions on the plastic but these should polish out. I believe that it is a vacform of the kit canopy.
- The bomb bay is quite nice but will require a bit of extra detailing as you can only cast so much into something like that.
Like any model, what is provided is only the base for a model. This is definitely better than the original but extra detail does need to be added for a top notch version eg cables and other items.
Here is the link to the original AZ Vengeance build:
http://forum.aussiemodeller.com.au/view ... f=8&t=1863
Site Admin
Postby harvs73 » Fri May 03, 2013 5:58 pm
Now I have finally received the Az Models Vengeance kit I have taken a few comparison images. Here are the panel lines that I am concerned about. The misaligned ones are not a war stopper as they are easily rectified but it is a pain. I have marked the panel lines with the green marking pen to give an indication of what I am talking about. The forward section of the bomb bay is probably the worst for alignment but in fact would be the easiest to fix as I am opening up the bomb bay on this build.
Site Admin
Postby harvs73 » Fri May 03, 2013 6:02 pm
These images give you an indication of the difference in size and shape between the original kit fuselage and the OzMods version. I have aligned the fuselage halves by the rear of the cockpit opening. The middle image has the halves still aligned at the top of the fuselage, this is a good indicator in the large difference between the two parts.
Site Admin
Postby harvs73 » Fri May 03, 2013 6:03 pm
Some more comparison images between the original and the OzMods version. The OzMods parts have been given a coat of Humbrol US interior green.
Site Admin
Postby Chrisrx » Mon Jun 03, 2013 1:33 pm
looks great dave, definately not a plane that was as popular as the spitfire, zero, 109 or mustang but well worth the build. great internal detailing of the ozmods upgrade kit.
Chrisrx
Postby harvs73 » Mon Jun 03, 2013 6:01 pm
It certainly is a good kit, I just need to get time to do more work on it! Alas, work keeps getting in the way :-(
One small bit of info, it seems that the fuselage problems I have are not replicated on other fuselages, the problem of getting one of the first one's off the line I suppose :-)
Site Admin
Postby dreamwriter » Sat Jun 02, 2018 10:49 am
Hello David,
Did you finish this build?
Bruno
dreamwriter
Postby harvs73 » Mon Jun 04, 2018 7:24 pm
Bruno, not yet unfortunately though I was thinking about getting back to it soon.
Site Admin
Postby dreamwriter » Mon Jul 02, 2018 9:47 am
Hi David,
Thanks for the reply. Can you tell me if the fuselage halves on your set were warped? Mine are,to the left if you look from the front of the fuselage. Another problems I´m dealing with are:
-If I try to align the cockpit floor to the top of the bomb bay detail,the cockpit does not stay levelled and leans to the right.
- If I do align it to the top of the bomb bay ribbing detail, the instrument panel sits too low inside the fuselage and leaves a hole between them.
Did you manage to close the fuselage yet?
Bruno
dreamwriter
Postby harvs73 » Mon Jul 09, 2018 7:26 pm
Bruno, the alignment of the panel lines as illustrated in my images is not the greatest. I did find that the fuselage isn't warped but the edges curve in at the join and will need either lots of filler or using warm water to bed them up in line with each other.
I did some work on the interior but work stopped me for a while and I didn't get back in to it. I am determined to finish the kit as I want a Vengeance in my collection as I gave away the original one I build using the AZ Kit. The image below is of the AZ Kit built from the box with a little work done on it.
Site Admin
