starting from scratch - advice apreciated
Postby Homerlovesbeer » Sun Feb 01, 2015 9:06 pm
Hi guys,
I hope you guys can help me out. I haven't touched a model for 20 years and have decided to have another go at it.
So...
I will be needing to buy everything from scratch. I was thinking about buying Mr Hobby or Mr Color paints as I've read lots of good things about them but i have no idea whether to go water based with Mr Hobby or thinner based with Mr Colour.
I'll be building aircraft and cars.
What are thoughts on this?
I'll also need to buy a compressor and and airbrush but I've never really used an airbrush before and don't really have a clue what to buy or look for. What do I need to look for and what will i need to spend?
What other "must have" items should I get? I was thinking about using Tamiya extra thin for glue.
Primers and thinner suggestions?
Cleaning solutions?
Brushes?
Sanding and scribing tools?
Clear coats? Washes?
And where does the money end??
Homerlovesbeer
Re: starting from scratch - advice apreciated
Postby DesTROYer » Sun Feb 01, 2015 9:29 pm
Hobby knife with a good supply of spare blades, Tamiya take in 6, 10 and 18mm, a decent set of sprue cutters, sanding sticks/paper, a variety of different sized and shaped brushes, a thinner matched to the paint you choose, cotton swabs and a variety of glues. Tame extra thin is good. I use it a lot, but Superglue is needed if you want to work with PE.
For a beginner a cheeper duel action airbrush and small compressor will do you> have a look on eBay at the ones they sell for airbrushing finger nails. You should be able to get a combo for a decent enough price. That should be enough to get you started. don't over stretch on your early builds and stick to a simple project at first. Try to add one new skill and tool to each build. YouTube is your friend. Heaps of tutorial videos there to teach you almost anything you need to know.
Postby RAAFBrat » Sun Feb 01, 2015 9:54 pm
What Troy said but I keep it even simpler. Sticky tape or insulation tape rather than Tamiya tape (it's expensive ;) ), Tamiya acrylic paints thinned with Metho & Revell model glue & Aquadhere for glues. Maybe a bottle of decal-softener - I use Tamiya "Mark-Set".
My airbrush is a little Makeup/Cake Deco set I got off EBay for $60.00 - it does the job well I think. Keep it simple to start with & go from there. Good luck! :)
Postby DesTROYer » Sun Feb 01, 2015 10:01 pm
Tamiya tape can be bought in bulk on eBay for the same price as one roll here in OZ.
Postby RAAFBrat » Mon Feb 02, 2015 6:40 am
Thanks Troy. I'll take a look :).
Postby Homerlovesbeer » Mon Feb 02, 2015 11:18 am
Thanks for the input guys. What are the thoughts on the paints?
Homerlovesbeer
Postby RayS » Mon Feb 02, 2015 11:27 am
The Gunze Mr Hobby paints are nice and easy to use though the range is getting harder to find in the local shops, apparently the imported has stopped bringing it into the country. The only stockist here in Canberra is selling what's left of their stock at 20% off to empty the rack since they can't get any more.
You might want to try for a range that is available locally, where are you located?
Postby DesTROYer » Mon Feb 02, 2015 12:00 pm
I use Lifecolor, though some people have difficulty in shooting it, second choice is Tamiya, then Gunze. All are acrylic.
I like Lifecolor because they have all the FS paint numbers I use a lot. Australian and US Aircraft and armored vehicle colors.
Postby Homerlovesbeer » Mon Feb 02, 2015 8:33 pm
Well guys thanks again for your help....I bit the bullet hard tonight and went a bit crazy!
The paints are all Mr Hobby (Mr Color) water based acrylic paints with the order done through BNA Model World. I bet there is a forum discount I didn't know about too :?
1 x 1/48 Messerschmitt Bf 110G-2 (Weekend Edition) (ED 84140) AU$25.00
1 x Modeller's Side Cutter / Sprue Cutter (Alpha) for Plastic Modelling (TM 74093) AU$14.39
1 x Ultimate Modellers Sanders -Multi Pack (3pcs) (UMP013) AU$12.75
1 x Tamiya Extra-Thin Cement (TM 87038) AU$9.55
1 x Tamiya Tool Series - Fine Pin Vice (0.1-3.2mm) (TM 74050) AU$19.04
1 x Water-Based Acrylic - Gloss Red (10ml) (GSI-H003) AU$3.69
1 x Water-Based Acrylic - Gloss Yellow (10ml) (GSI-H004) AU$3.69
1 x Water-Based Acrylic - Gloss Blue (10ml) (GSI-H005) AU$3.69
1 x Water-Based Acrylic - Gloss Brown (10ml) (GSI-H007) AU$3.69
1 x Water-Based Acrylic - Metallic Steel (10ml) (GSI-H018) AU$3.69
1 x Water-Based Acrylic - Gloss Russet (10ml) (GSI-H033) AU$3.69
1 x Water-Based Acrylic - Gloss Dark Green (10ml) (GSI-H036) AU$3.69
1 x Water-Based Acrylic - Gloss Wood Brown (10ml) (GSI-H037) AU$3.69
1 x Water-Based Acrylic - Gloss Pale Green (10ml) (GSI-H041) AU$3.69
1 x Water-Based Acrylic - Semi-Gloss IJA Green (10ml) (GSI-H060) AU$3.69
1 x Water-Based Acrylic - Semi-Gloss IJA Grey (10ml) (GSI-H062) AU$3.69
1 x Water-Based Acrylic - Flat Khaki (10ml) (GSI-H081) AU$3.69
1 x Water-Based Acrylic - Semi-Gloss RLM 66 Black Grey (10ml) (GSI-H416) AU$3.69
1 x Water-Based Acrylic - Semi-Gloss RLM 76 Light Blue (10ml) (GSI-H417) AU$3.69
1 x Water-Based Acrylic - Flat Tyre Black (10ml) (GSI-H077) AU$3.69
1 x Mr. Metal Color - Aluminium 10ml (GSI-MC218) AU$4.48
1 x Mr. Metal Color - Brass 10ml (GSI-MC219) AU$4.48
1 x Mr.Metal Color - Dark Iron 10ml (GSI-MC214) AU$4.35
1 x Water-Based Acrylic - Semi-Gloss Grey (FS36320) 10ml (GSI-H307) AU$3.69
1 x Water-Based Acrylic - Semi-Gloss Grey (FS36375) 10ml (GSI-H308) AU$3.69
1 x Water-Based Acrylic - Gloss Red (FS 11136) 10ml (GSI-H327) AU$3.69
1 x Water-Based Acrylic - Gloss White (10ml) (GSI-H001) AU$3.69
1 x Water-Based Acrylic - Gloss Black (10ml) (GSI-H002) AU$3.69
1 x Water-Based Acrylic - Flat White (10ml) (GSI-H011) AU$3.69
1 x Water-Based Acrylic - Flat Black (10ml) (GSI-H012) AU$3.69
1 x Water-Based Acrylic - Metallic Silver (10ml) (GSI-H008) AU$3.69
1 x Water-Based Acrylic - Gloss Clear Red (10ml) (GSI-H090) AU$3.69
1 x Water-Based Acrylic - Gloss Clear Blue (10ml) (GSI-H093) AU$3.69
1 x Water-Based Acrylic - Metallic Burnt Iron (10ml) (GSI-H076) AU$3.69
1 x Water-Based Acrylic - Gloss Bright Green (10ml) (GSI-H026) AU$3.69
1 x Water-Based Acrylic - Gloss Smoke Grey (10ml) (GSI-H095) AU$3.69
1 x Water-Based Acrylic - Gloss Clear Green (10ml) (GSI-H094) AU$3.69
1 x Water-Based Acrylic - Semi-Gloss Grey (FS36118) 10ml (GSI-H305) AU$3.69
1 x Water-Based Acrylic - Semi-Gloss Blue (FS35622) 10ml (GSI-H314) AU$3.69
1 x Water-Based Acrylic - Gloss Grey (FS16440) 10ml (GSI-H315) AU$3.69
1 x Water-Based Acrylic - Gloss White (FS17875) 10ml (GSI-H316) AU$3.69
1 x Water-Based Acrylic - Flat Grey (FS36231) 10ml (GSI-H317) AU$3.69
1 x Water-Based Acrylic - Gloss Yellow (FS 13538) 10ml (GSI-H329) AU$3.69
1 x Water-Based Acrylic - Semi-Gloss Barley Grey BS4800/18B21 (10ml) (GSI-H334) AU$3.69
1 x Hobby Knife with 5 Assorted Interchangeable Blades (TR 09908) AU$9.50
1 x Mr. Aqueous Hobby Color Thinner 110ml (GSI-T110) AU$7.03
1 x Acrylic/Waterborne Polymer Primer - Neutral Grey (60ml) (AK-175) AU$8.09
1 x Masking Tape 6mm w/Dispenser (TM 87030) AU$7.76
1 x Tamiya Masking Tape 18mm w/Dispenser (TM 87032) AU$8.60
1 x Tamiya Masking Tape 10mm w/Dispenser (TM 87031) AU$6.75
1 x MicroSol Setting Solution for Decals (Soften Decals) (MI-2) AU$5.75
1 x MicroSet Decal Solvent (Soften Decals & Improves Adhesion) (MI-1) AU$5.75
1 x Model Colour Plastic Putty 17ml #400 (AV 70400) AU$4.95
Anything I've forgotten?
Homerlovesbeer
Postby DesTROYer » Mon Feb 02, 2015 8:56 pm
I hope you find you love the hobby and stick with it. lol
