FOD covers and engine bungs.
Postby DesTROYer » Sat Jan 24, 2015 8:56 am
I'm looking for ideas on how to make up the engine exhaust FOD covers/bungs for my Canberra, as seen below.
The intakes were pretty straight forward, but making the rear covers are making me scratch my head. I want to make them non permanent, so gluing and painting cling wrap on, in not an option. Thought about foil, but will it hold the paint without it cracking and flaking off.
Re: FOD covers and engine bungs.
Postby RAAFBrat » Sat Jan 24, 2015 12:36 pm
What about tissue paper? Wet, mould, let dry & paint? Works well for simulated canvas tarps.
Postby DesTROYer » Sat Jan 24, 2015 12:43 pm
I'll give it a go. Thanks.
Postby Calum » Sat Jan 24, 2015 1:46 pm
I used tin foil covered in tissue paper. I found the tissue paper on its own hard to work with when wet (kept poking holes in it)and when dry it was brittle.
I placed the foil over the intakes and exhausts, then placed the tissue paper over the foil and using a mixture of white glue and water dampened the tissue. When dry remove, trim to the size you want and paint.
Postby DesTROYer » Sat Jan 24, 2015 3:20 pm
They look great Calum.
I wasn't having much luck with the tissue either so I tried Tamiya tape and got some good results. I like your idea a lot though so I'm going to give it a go. Thanks.
Postby RAAFBrat » Sat Jan 24, 2015 6:15 pm
The other trick with tissue is to soak it with Aquadhere (white glue). Mould to shape, let dry then paint. That's what my boy did with his diorama. Tarp in the front corner & the muzzle cover.
Armour 006.JPG (38.96 KiB) Viewed 1926 times
Postby DesTROYer » Sat Jan 24, 2015 7:37 pm
Cheers. Once I've cleaned this up, I plan to try that for the cloth roof on the Canberra's sunshade.
