DIY Spray Booth
DIY Spray Booth
Postby TiG » Sat Feb 29, 2020 10:56 am
Here's something I cooked up a few months back. I was interested in getting a spray booth to assist extract the fumes from spraying in my man cave, and had read that the small, computer fan style extractors didn't provide enough cfm displacement for the sort of spraying with lacquers I normally do.
I did some research and found that a conventional 240V bathroom fan is very good at moving air. I also found that flash-point/explosion risk is generally pretty low, especially with a good filter and a centrifugal style fan system like this one, so that was good enough for me to give it a crack (please do your own risk assessment before building your own!)
Here's all the stuff - I bought the fan on Ebay for about $40 from China, along with the roll of filter material, hose and window connector. The black tub and LED light came from the local Bunnings. I went with a pretty decent sized one (75L, or 740mm wide x 465mm high x 280mm deep), as I wanted the space to handle larger jobs (maybe 600mm wide.
Parts
I then cut the hole to the right dimensions with a fine angle grinder blade and fitted the fan unit.
Cutting a hole
Install bathroom fan
Next add the layer of filter material, place the cover over the fan, and attach the hose unit:
Add filter
Attach hose
Almost done. Just got to set it up on the bench, screw in the LED light source, and connect the hose to the window:
Connect to window and add light
Voila
It works a treat! I plug it in a few minutes before a spraying task and it seems to suck all the dust and nasties in the immediate area of the room before you start adding paint to your project. It's powerful enough that you can see the vapours being drawn into the unit, and the amount of reside/overspray is minuscule compared to the layer of paint 'dust' I once ended up with on every surface. I have taken to lining the base of the tub with Chux wipes, and placing the model on a a small cake decorating wheel base to allow 360-degree rotation of the model while spraying.
Thanks for viewing.
On the bench: 1/48 Tamiya He-219 Uhu.
"To improve is to change; to perfect is to change often"
Re: DIY Spray Booth
Postby Viking » Sat Feb 29, 2020 8:13 pm
Nice work!
I built one similar, but used the 12v computer fan. Not a good idea, as it had near-zero suction.
Viking
Re: DIY Spray Booth
Postby qfa_tsv » Sun Mar 01, 2020 8:49 am
Very neat.
also Interested in your overhead work light, where did that come from
Re: DIY Spray Booth
Postby TiG » Sun Mar 01, 2020 12:22 pm
Thanks fellas. The light is just a little Arlec LED unit I picked up at Bunnings for around $18. It has three different color settings (warm, cool, and daylight I think). It provides good illumination for spraying.
