How to build a cheap and efective paint booth
Postby fjs » Thu Sep 21, 2017 10:29 pm
Hello all, I recently built myself a paint booth for airbrushing my models. This is a guid to how to build a booth however large or small you want.
These are the dimensions of the booth i built. I sketched out my design on CAD to get an idea of what it would look like before i began, and also to figure out how much timber i needed.
I bought a 12mm 1.2 by 1.8m piece of timber and drew out all the parts before cutting them with a circular saw.
There are two main parts to the booth, the first is a fan housing, and the second is the actual boothy thingy part. The fan housing is made up
of six parts. four, 170 by 388mm pieces one with a 102mm hole cut with a hole sore, then two, 400 by 400mm pieces one cut with a hole in the middle for a 250mm fan.
Next, the booth comprises of four parts, they are all eregular shapes so i put the measurments on the picture...if you can read them :?
I used liquid nails and a fixing gun to construct first the fan housing, then the booth, but they needed some encouragement to come together.
I also added a hole on the side of the box for the power lead from the fan.
Next i gave it a lik of paint.
Finally i add all the goodies, i used a high volume fan that i picked up second hand from a renovation, but you can buy them from bunnings for about $20, some LED lighting, and the 100mm ducting adapter.
And finaly it is compleat!!!
List of items used and prices:
Timber......................................................$29
Lights.......................................................$16
Fan..........................................................$20+
100mm back-draft dampening ducting adapter......$29
Paint........................................................FREE!!!!...unless you dont happen to have some laying around, in which case you can buy some for around $20
ducting hose...............................................$20
Total........................................................in or around $130. but you can pay a lot less if you go second hand components.
and there you go :D
Hope this was healpfull to some of you and pleas let me know if it was, and if you have made one yourself pleas feel free to poste a picture of it on this thread
Tanks! fjs
Airfix 1/72 p 51d Mustang
motivation/advice for modelers:
"Better is the end of a thing than its beginning, and the patient in spirit is better than the proud in spirit."
fjs
Re: How to build a cheap and efective paint booth
Postby DesTROYer » Fri Sep 22, 2017 10:12 am
Nice.
